sl1210
Hi guys,
A customer is re-arranging their kitchen and will be moving their oven about 4 metres further down in the kitchen, where the current feed to the cooker switch is.
Is there a maximum distance you can have from the switch to the cooker connection unit???
In this case it would be 4 meters
Cheers
can and worms springs to mind.
Some will suggest isolators are not required - which is madness. IMHO all fixed appliances should have DP isolation.
back to the OP - within 2 meters is a guide.
ok well then would it be a problem for the original isolator to feed the new isolator position. or should i just remove the old isolator and crimp the 6mm in the back box and just blank it off??
Is it nearer the CU or further away? Is it a small make over or a complete refit? Only you can decide as you know the site!
the whole place is sort of being worked on and the floorboards in the lounge are exposed and its an easy run to the db. but after i advised them re-running new 6mm from the db to new switch they said they would rather the cheaper option (which would be this)
Please bare in mind that the 2m figure is a guide. TBH as long as the switch is clearly identified and labeled and readily accessible then i can't see a reason to rip everything up to resite.
If it is labelled as to what it isolates, and is within view of the appliance, then just leave it where it is. I mean, how many times are bathroom fan isolators put outside the bathroom? Mine is actually on the floor above the bathroom. Do I lose sleep? Nope.
hypothetical question .....
if the CU was 1.3 mtrs to the side of the cooker , would you fit a DP switch that could not be any closer than 1.8 mtrs away from cooker ?
trouble making git arent i ? lol.
Yes I would to ensure DP isolation so when the RCD tripping starts you can rule out the cooker easily.
People who install fixed appliances without DP isolation should be shot for shoddy work.
I agree but after all the regs for TN systems do not warrant double pole isolation apart from the main switch of the C.U.
