Discuss How many circuits do I have in the DIY Electrical Advice area at ElectriciansForums.net
Forty_Two
I want to get an EICR on my house, the cost seems to be based on how many circuits I have - what do I do to find out how many circuits I have?
Count all your circuit breakers and/or fuses bearing in mind some may not be in use even if there is one there. Post up some pics.
I have two CU's. On under the stairs that serves the house and one in the garage that serves a two room extension and the garage. Some of the 'fuses' are not in use e.g. there is one RCBO in the garage which is waiting for my EVC to be installed.
Single insulation on mains connection to bell transformer. C2 or possibly C1 if exposed copper showing.
Whole second CU shouldn't be in the meter box, but that's nothing to do with an EICR.
is this the thing you refer to? (I don't think it supplies anyting 0 I don't have a 'bell')
Reactions: DPG
If it's not in use then it could do with disconnecting and the feed cable removing.
You have at least fifteen circuits. Without physically carrying out the EICR it is impossible to say from a few pics whether it would be satisfactory or not.
Reactions: DPG
They will still charge to test the circuits at whatever price they said... Its only if they find C1 or C2 problems they will charge extra for repairs (or quote for them)
Most places charge per circuit. Sometimes its easy, sometimes more difficult if they don't know what circuit supplies what, and there's a lot of investigation involved.. Swings and roundabouts.
Possibly a quirk of the garage photo angle, but I see 3x L cables but only 2x N - maybe the third N is hidden behind the red? Also the red L looks possibly to have the sheath stripped back, but the resolution is not high enough to see properly.
Same photo, the E from the 8-way earth block to presumably the main CU looks to be old unsheathed tinned copper & possilbly is too thin, but again hard to tell with the photo resolution.
Out of interest, what is the reason for the EICR - own peace of mind, selling up, something else?
Reactions: DPG
I'll start a new thread where I will answer that question
The question I posed in this thread has been answered - thanks
Reply to How many circuits do I have in the DIY Electrical Advice area at ElectriciansForums.net
Hi everybody, I've been asked to do a EICR in a commercial property, So i popped in to have a look on my way home quickly and found the lighting...
For example the house today had two lighting T&E in the same MCB. I know it's fine, but as I test both 'radials' where and how do we enter them on...
Hi everyone. I should start by saying I'm not sure I'm in the right place here (this isn't a householder issue - I'm making a Ghostbusters...
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
Hi all, Been asked to quote an EICR on a fairly large installation. Approx. 400 circuits that are a mixture of single and 3 phase. This is across...
