Discuss How tight is tight. in the Electricians' Talk area at ElectriciansForums.net
Kyran
Ok so we all know we should do good connections, tight so they don’t creep out of create loss connections.
I know that there is a specified newton tightness but looking in the BGB I can’t see the value and i looking in the wrong place.
reg 526.1 “every connection between conductor or between a conductor and other equipment shall provide durable electrical continuity and adequate mechanical strength and protection.”
Thats all great but how tight should it be?
Can anyone point me at the right reg/value.
All connections should be tightened to the torque stated in the manufactures instructions, there isn't a one value suits all for what a connection should be tightened to.
So it is, just looked in the the box of a waterproof CU i have in the cupboard and sure enough in the first flap "installation" its as terminal bar 1-1.5 Nm and RCD/MCB 2-2.5Nm
Should have look there first
Thanks. Its just one of those regs that just refers to to the manufactures. Ops thanks peps.
well they weren't going to exactly list every make and model of consumer unit along with the required torque setting in the BGB/BYB were they lol
Reply to How tight is tight. in the Electricians' Talk area at ElectriciansForums.net
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
How does a terminal become completely loose? My uncle had an old school outside socket installed ~40years ago he asked me to have a look as it...
4K
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
