The clock time would be set by turning the central button to the correct time.
The on and off times would be set by moving the dip switches around the edge in toward the centre (probably for on time) or out away from the center (probably for off time).
These operation may be the other way round out as on and in as off.
The switch / button on the bottom right would be for changing from constant on / timed operation / off.
What two arrows???
The single black arrow near the inside of the dial indicates the actual time of day. You rotate the knob in the middle until it's set at the correct time. To set the on and off times you push the appropriate little segments in that are around the outside of the dial.
I thought the actual time of day was the white arrow located at the 3 o'clock position. You can't see this arrow in the picture but there is a line going up from the selector switch pointing into it. Then I'm confused about the two pointers/arrows. When I turn the centre dial the two arrows move around. The outer one moves around at a faster speed.
The two arrows are a clock - at 10 to 2 - which corresponds to 1350 on the 'east' position mark.
