Discuss How to solve an iPS alert in SCADA system in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone!
I just took over an SCADA system and i discovered we have an iPS with an UPS.
There have been a trouble with iPS. A long beep every 3 seconds with LED "communication indicator" is RED. It seems battery is missing. I have just graduated and have no experience. How can I do to solve this problem?
Btw, it is a IDEALPLUSING iPS-RS22040
If the 3 second beep indicates a battery problem, although it is there… check the terminals are tight into the battery, or replace the battery.
They possibly have a “replace by” date on them.
I don’t know the equipment at all, so I only assume the battery is the square brick type you find in fire alarm panels.
Hopefully someone else has had experience with these.
Actually, they're not popular. I can't even find the User Manual. I only know they are used for high voltage power plants and substations. And the square brick you mentioned is a Rectifier module ?
Try this
I see. Thank you. I'm not sure it helps me much, but I'll try
Reply to How to solve an iPS alert in SCADA system in the UK Electrical Forum area at ElectriciansForums.net
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
