Darkwood
As 95% of my work is panel building and machine repair i actually use this forum to stop me falling behind with general installation regs... anyway was at a factory other day and he has his own sparky that has pre-installed a 5core 4mm swa to supply 3 steel containers they want lighting into and a small compressor supply.
As im doing my pricing at our lasses ive not got regs to hand so just clarify my thinking here pls.
The incoming supply is to a 3ph 4way Bemco TNCS and if i wanted to extend the existing equipotential zone to the steel containers i would need to run a 50mm earth with the existing swa thats been already run, this is now buried in concrete so not an option.
This leaves the only other option of isolating the swa earth at load end and TTing the install there onwards
Ive also instructed the owners that the existing equipotential bonding is undersized at 10mm and should be upgraded to 50mm to Gas, Water and Structural...
The reason i ask is he called this now retired sparky who insisted i was wrong and didn't know what i was talking about assuming to save face but although my confidence is high ive just having a blonde moment and questioning my insanity lol .... please point out if ive been a tithead here it has been known to happen to the best of us
when you argue who's correct sometimes you end up with a seed of doubt yourself.
