Discuss HV Schneider Breaker in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
We have a HV Schneider GenieEvo breaker, on the name plate, this device is rated for 50Hz. What would happen if we used a 60Hz supply? Can the 50Hz breaker be able to take 60Hz.
thanks
Since they are VCBs the breaking capacity should be similar/identical between 50 and 60hz, however the overall switchgear will contain CTs and possibly VTs , these are likely to be specific to a particular frequency.
I'd say definately not compatable unless it states 60Hz in the spec sheet or you get confirmation in writing from Schneider tech support.
Hi all,
thanks
pretty sure from memory they are indeed designed to work on both frequency's, Best check with Schneider but I think they will work on 60 HZ
Reply to HV Schneider Breaker in the UK Electrical Forum area at ElectriciansForums.net
I was looking for the likes of the SQB1603K and see it is out of stock at CEF and no delivery option available. Odd. Then I search for the part on...
Having trouble figuring this one out. House was built 5 years ago. Eaton box and breakers. Over the past 3 weeks, the bedroom breaker keeps...
Hello, We have been asked to install A Modicon Controller to provide PC control over an existing installation that has contractors/key switches...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Hi everyone, I have a basic knowledge of electric but would like advice before I attempt, I have a electrical item that is powered by Voltage...
