Y
YoungBart
Hi all
First let me say sorry for posting something that will no doubt have been posted many times before, But after scanning similar threads none seem to answer my question.
Tommorow I have an IR test as part of my 2391, Only 20 minutes, two global tests to be carried out (with different faults), Basically We've been told to test at the incoming tails, (all are there and on show), So obviously i'll have my main switch/RCD ON, as well as all breakers, test between, L-N, L-E, N-E, The testing bit is all straight forward, and I know the difference between an Earth fault and a Short cct. But I never know when one of these faults becomes a Low IR fault. We've been told that if we get 0Mohms on the IR test too turn the tester to Kohms and see what reading, My understanding is that if it's zero Kohms it's likely to be a short or a E/F if however there is a 'result' for Kohms it's likely to be a Low IR.
Am I right or is there a simpler/better way of knowing?
Thanks again
James
Thanks again
James
