DanMoe12
Hey,
I just registered here and I am happy to have found this blog. however, i get logged off occasionally :( does anyone else experience this - if not, any ideas why this problem occurs?
You will get logged out after a while if you are not using the forum, it used to be about 15mins but since the forum was updated it is longer not sure how long.
The forum will log you off after a period of inactivity. I's a good idea to tick the 'Remember Me' box when you log in that way you should stay logged in until you manually log out. The other advantage of doing this is that if you're a slow typist it will save frustration of losing a long post after you've spent ages typing it and your login has been dropped before you've hit the Post Reply button.
