Discuss Identify old 3ph DB in the UK Electrical Forum area at ElectriciansForums.net
S P
Good Morning all
Can anyone confirm what this 3ph DB in the photo is?
I believe it is a Crabtree C50 but looking for some confirmation from more experienced eyes.
Many Thanks
Welcome to the forum S P :).
Yes looks like one, drop a mcb out and its usually written on the side of it, if your stripping it out keep the mcb's as they are like rocking horse doo doo, they are good as a temp' fix on old installations with faulty breakers while you discuss a more permanent solution.
BS3871's, M4.5 and the ampage is on the end of the switches.
Yes Crabtree C50 I believe they have yellow , white or plane marking indicating the type, as above there is more info on the side of the MCB
Reply to Identify old 3ph DB in the UK Electrical Forum area at ElectriciansForums.net
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hi all, my friend has just moved into a property and I've had a quick look at his DB and was greeted with a very old Crabtree board. Could someone...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
Does anyone know offhand which SP MCBs are compatible with Crabtree Powerstar 3Ph boards? I need to take a 60a supply from this board but I can...
