Discuss Identifying live cables in the Commercial Electrical Advice area at ElectriciansForums.net
hi gents . I’m currently surveying a property prior to remodelling it... it was a department store and it’s been redeveloped at least once but no one has pulled out the old wiring,
I want to mark up any of the major 415 3 phase that is defiantly live ina simple way so we can focus on tracking and verifying potentially dead cable most of the stuff I’m talking about is between 1.5 inc and 3 inc sea. Will a volt pen do the trick or do I need something different. Obviously anything that seams dead needs tracing and proving before we do any work . I just want to be able to quickly show what’s live so we can protect them and get them shown ondrawings
1) I will need a team of sparks befor I’m finishe 2) no I don’t, I have always proved cables at one end or the other or been able to isolate the whole supply. This building is prity vast so when I am sticking my head in places I don’t rally want to go back to and I see a big black cables 2 inch thick I would like a quick way of determining if it’s deep live then I can mark it on the plans. If a volt pen will do volt pen will do it then that will do.. any cables I don’t get a positive result for can get marked up as require further investigation.
However if there is something a bit more reliable than a volt pen I will get one,
1) If a volt pen will do volt pen will do it then that will do.. any cables I don’t get a positive result for can get marked up as require further investigation.
In your case the thing more reliable is someone qualified to test correctly and inform you.
It could be very dangerous going about things in the way you intend.
Volt pens are good as an indicator, but won't work through the sheath of many cables.
What cables is it? You mention 2" thick......SWA I'd imagine, a non contact volt stick won't pick that up.
We're talking 400v, here TJ. 'Prity vast' sounds like it could be quite complicated to me ( a bleedin' department store), could be cables all over the place. What about sub boards, removing live fuses, etc. God knows what could be live and what might happen with attempted removal.
I know......Totally agree!! Shouldn't be relying on a volt stick for it. If he is getting a spark in anyway....why can't they do it....
My new fluke t6 1000 arrived yesterday.
I’m going to start putting it through it paces tomorrow so will let you know but then that will only be useful for single cores...
What you are attempting to do is very much involved.. There is specialist equipment available to identify individual swa cables but need to be used by competent operatives..
I have regularly been asked to make building sites safe for demolition/refurbishment works.. my solution - isolate everything and set up temporary supplies..
If these cables are going to be defiantly live you're gonna need to make doubly sure those stubborn buggers are dead.
No a volt pen will not do. You need someone who knows safe isolation procedure in accordance with HSE guidance and compliance with the EAWR. They need to be using approved equipment and have the knowledge to use it correctly. In short, an electrician.
Any blundering about with limited knowledge and volt pens could put people in serious danger, and those that have put them in danger exposed as incompetent and action taken against them.
Thanks ty for the constructive response. TJ the cables are Mostly big .others .are f’ing .. IPF is correct though there are sub boards everywhere and his implication reasonable if incorrect . I came across an installation today that ,looked derelict but on closer inspection still had one apparently live main switch with a supply going somewhere So marked it on the plans as poss live needs further investigation ( I suspect it feeds a lift Moyer 4 stories up) I also found a cable that entered the building 30 m from where i would have expected it to I know that’s live because I can see the meter going round ...that’s going down as arrange dno to relocate meter. However some of these cables I don’t think we can easily trace back to source or termination to prove. So at this stage being Abel-to show a cable is live or possibly deadwill help me plan the works.
Reply to Identifying live cables in the Commercial Electrical Advice area at ElectriciansForums.net
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
Hi there - some of you might have seen my previous post about current-measuring CT clamps. This is another question about them! Once again I'd...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
Hello everyone my name is Tarek, i work as a concert and show lighting operator with over 20 years of experience in this field, so i have gained...
I have multiple large looms of various cables that I need to trace. These are various services including power, fibre, copper, other 'unknown'...
5K
