F
Fireblade
Hi Guys...
Just wondered what you thoughts are on the following and what course of action you would take? For the record, I have notified the owner of the property and have rectified the situation but not quite sure what the best approach might be with regards to the person responsible for the original work done...!?
Client had to have a replacement hot water tank fitted due to pin hole at the base of the unit, original tank was only supplied with "off peak" power. Client's plumber fitted a larger tank with a second boost element for all the right and obvious reasons - this however is where the fun starts....
There is a double socket on the landing, the reverse of which backs onto the airing cupboard, it already has a spur from the socket - however the plumbers electrician has taken a "second" spur from this point through the wall to a swithched FCU to feed the 3KW element plus a radial double socket for a power source to hot water booster pump (starting current of 1amp with full load of 0.48amps)..
So my issues are:
1. Shouldn't have taken 2nd spur from socket
2. Any water heated fitted to a vessel in excess of 15 litres should be supplied by there own separate circuit.
Would appreciate your thoughts...
Cheers
Unfortunately you are being optimistic that there is any recourse available.
The electrical work as he has done it did not need building control notification, he has not complied with the wiring regulations but it is now OK and I expect he would not have supplied any certification.
No one will be interested unfortunately. Now that you have rectified the work then there is nothing realistically that can be done.
You could mention this to customers but that sounds like you are just bad mouthing competition.
Ain't life grand!
Oh and it is possible to take a second spur of a socket that is part of a ring so long as it is not a spur off a spur but it would not lead to even loading on the ring.
Last time I saaw something like that I asked to see the certificate the Electrician had provided .... deafly silence followed!
Fireblade,
Octopus,
