Discuss Incoming services becoming live? in the Industrial Electricians' Talk area at ElectriciansForums.net
B
boss
hey guys, nice forum by the way. This is my 2nd post I think but any way here goes.
In what circumstances have you dealt with or heard about (stories etc) have you found the incoming services to be live, such as gas pipes, water pipes? whats the possiblities.....
cheers
Hi
The incoming service are often live ,not sure quite what your asking ,if they wernt then it would all be a bit of a waste of time,.
have i missunderstood yer question?
its so under a fault conditions your main earthing conductor fails its a secondary protection method to earth to ensure disconnection of supply.
Hi all, If the bonding was not earthed to the main earthing point and there was a phase to earth leakage wouldn't that make the pipes, rads etc have a pd from the earth?
Paul
Surely if there is no earth path fr the current to take there will be a voltage in the bonding ie rads and pipes? or am I missing something?
paul
Reply to Incoming services becoming live? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hello guys. I have a question as being in Africa for 15 years, I used to use a mustimeter to check voltages at the light switches as they got...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
