Discuss Inspection & Testing in the Canada area at ElectriciansForums.net
M
Mark2009
Hi
What are the laws on testing in commercial buildings?
If i run in a extra 4 sockets i was led to believe that you need a N.I.C.E.I.C Certificate but also i am told you can get the green certificates from N.I.C.E.I.C which will state the test results.
I spoke with the N.I.C.E.I.C today and to my amazement its down to the actual company what certificate they want.
I have ordered the Green Certificates today, from what i am told many more Companies don't seem to ask for a test certificate.
Just advice please.
Mark
The only rule is the installation should be tested and test sheets completed any test sheets would do however as usual most larger companys believe only niceic forms are acceptable........
Plus, you should also check with the client.
Sometimes they, or their insurance companies require NICEIC or ECA registered contractors to carry out the works.
Hi
Thanks for this but the more i talk to people the more i hear of people not using NIC Certificates.
Mark
Yes but this is outside the scope of Part P for eg, so therefore, there is no requirement to belong to any scheme, as long as certs are produced for the work.
BUT, some companies insurance requires the contractor to be registered with one of them.
Then, on the other hand, if they dont request it then no prob.
Make sense?:D
Reply to Inspection & Testing in the Canada area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
I recently just done my AM2 resit and in my inspection and testing, despite the invigilator watching me do the tests, I think I may have forgotten...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
Hi all My Fluke tester failed on one test today while having it's annual calibration, the continuity resistance test current. Test Current -...
