inspection & testing
I ask because I have been working recently with sparkles who have 30 years experience and they just wiz through testing. I do respect their knowledge but I am sure they must be cutting corners no matter how experienced and I am too polite to question them, hence, why I've asked the forum.
even a smallish job. say 6 circuits. half a day test/inspect and an hour to write up the cert. to do a eicr in 1 hour is about as ludicrous as learning to be a qualified spark in 5 weeks. wonder if there's a connection.
When I price a house, I price at a hour per circuit. I feel this is adequate to remove lamps/dinners/neons etc per circuit. We have never won a domestic EICR as we are to expensive! In fact we never get any domestic work at all! Had to don some work on a managers house recently to satisfy the NQA!!
Well, it takes me several hours and I like to be as thorough as possible but I have heard of guys completing an EICR in under an hour. I just can't see how this is possible. If anyone has any tips to be faster and accurate, I'd love to know.
Ask if you can tag along with one of these guys to gain their secrets. Although I'm pretty sure you can already sit in a van and invent readings.
The average house I price for a full day based on a 3 bed house, no lifting of floors, no guaranteed access to loft space, and 1/3 of accessories removed for inspection sample.
I'd rather have a bit of time left over than try to rush another one in.
Nobody can do it properly in an hour. 30 years experience or not.
Makes you wonder what they would actually do in "the hour" - often takes me longer to complete the cert!
I have given this some thought and I recon it’s doable. All you need is the previous inspection report and some Tipp-ex. A quick change of dates and the job is a good’un! :angel_smile:
Good thinking Batman, just need to find a previously completed cert for my next job now .....
boss of a firm i once worked at wanted me to do 9 EICs in one day .
it would take a day to write the results up i said .
he said , test the first one and use that as the basis for the rest of the results :confused5:
I usually go for 100% inspection of accessories on domestic, unless I really need to save time (i.e. the customer is that tight fisted). Used to do 50% sampling, until one time I missed a DIY lashed up cooker switch that later almost melted, and I had given the installing a 'Satisfactory'. I know you can't check everything, as most of the installation is hidden away, but I like to check everything I can get to nowadays. Right down to checking fuse ratings in FCUs.
Incidentally, this brings me onto another issue I encountered recently. As far as I am concerned, stuff on a plugtop isn't part of the fixed wiring, but what would you guys do if you came across a terrible arrangement of six socket outlets (screwed to the wall) fed from flex going all around the room and plugged into a single socket? Room only had the one socket and there was a heater, TV, PC and other stuff plugged in.
100% external inspection of accessible items is about the minimum.
The multi sockets is a comment that there are not enough socket outlets (which does almost come under BS7671).
Joking aside, I know a local electrician that does that. In the pub, he can always be found at the crackpot end of the bar. He asked me only yesterday if I could put in a good word for him at my place. Ohhh how I laughed! The thought of that conversation between him and my “Big Chief running with dough”, when he hands his paperwork in. I’m already visualizing the special time that EICR will have up his backside….pml
I will tell how they do
Ze test done
Turn cu off, link L to E on whole board
Run around taking R1R2 at furthest looking outlet on each circuit
quick calc for Zs
rcd test at board if there is one
no IR test no cont. test
jobs a goodun
certificate not worth a damn through
come across it loads of times
mind you the new EICR cert takes abit longer to tick off but still seeing the old PIR certs being used
I take a similar'ish view if its on a 13A plug "circuit". All depends on loads, cable sizing, number of sockets & extension leads but generally ......
If I consider it safe/reasonable I just raise it as an un-coded observation that its been found acceptable but could be improved. (A butt coverering exercise!) e.g. its no different to essentially being a "13A FCU" -- I guess a bit like your 6 sockets!!
If I consider it needs improvement then I grade it C3 -- e.g. insufficient sockets for the room and extension leads on extension leads are being used to compensate for a lack of socket outlets.
If I consider it dangerous/unsafe I grade it C2 -- e.g. potential for overload due to the types of appliances being used on it and leads trailing under carpets/covered etc...
