Discuss installing a temp generator in the UK Electrical Forum area at ElectriciansForums.net
I have a small bungalow sized building which I essentially a hut.
They lost power and the DNO may not rectify for a while.
The building will need a temp generator and only needs 3kw of power, asides from checking up on the regs can anyone offer some advice through their own experience?
I'm sure your aware, but just in case, make sure you isolate the bungalow from the dno supply as someone fixing a fault down the line may not appreciate a sudden return of power from an unexpected source.
Just out of curiosity, as I don't know a lot about generators: Correct me if I'm wrong but generators run more efficiently at the top end of their rating, about 80% and above?
So how would you size a generator for a house when the power consumption is a lot different during the day than night? Yes you would have to size it for the max power used....
In the OP's case, they are using a 3kW gen. At night time the small bungalow may only be using about 300W (TV, TV box and lights). Except for when they are making a brew or course.... So isn't the gen running way under efficiency?
I had to do a changeover in a hospital we had a big genset for most of it but used the Honda inverter ones in some areas and agree they are a good set and quiet just the job for what you need I should imagine. What else you need to do will depend on the existing install
The hut owner should be speaking to the DNO.
If the power is going to be off long enough for them to justify a generator then the DNO should be providing it.
If it's a multiuser problem they normally put a local generator(s) on the consumer side of the fault until the issue is sorted.
What was the site earthing system and how was the shed earthed? Any bonding?[/QUOTE]
So currently there is a TNS supply which has been isolated.
The mains bonds are connected to the MET for water.
No gas in building
Reply to installing a temp generator in the UK Electrical Forum area at ElectriciansForums.net
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Hi, I've been asked to look at installing a generator changeover switch at a property, so that they have some level of backup in the event of...
Just a query. As people have been asking me about changeover switches and generators. If a domestic house already has PV solar, and customer...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
