M
marc_v33
Hi guys, when doing a consumer unit change does the DNO have to install a double pole isolator? or are we allowed to install them?
The housing association which i have been doing work for were advised by DNO " why dont you just get your electrician to fit isolator"
Now is that .... we will carry out isolation and re-energise for you to allow to install isolator
OR
with specific training the electrician can carry out all works???
Cheers,
Marc
Fitting it is not an issue. It's just removing the fuse to isolate. The DNO frowns upon removing seals and fuses.
Worth giving them a call to see what they say IMO.
