Discuss Insulation readings in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m confused. I recently carried out insulation resistance test on a 3 phase board I had some weird readings.
I removed all vulnerable bits of kit and tested the dead side of the incomer all readings where good a part from L2 which had a low reading of 2.8M ohms. This was much lower than all other readings.
Any thoughts ?
Reply to Insulation readings in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
Hello, I’m testing some electric meters. As the circuits have no load on them to prove each ct I’ve plugged a hair dryer to simulate a load and...
I’ve had a weird one today. Banjo having 50v on it. L - main earth = 230v L - N = 230v N - main earth = clear I have 50v on the live - banjo &...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
