Discuss Intelligent Lighting in the UK Electrical Forum area at ElectriciansForums.net
Evening all.
I have been asked by a Company, to install the feeds to a new intelligent lighting system for a customer. The system will be installed by the separate company.
Having spoken to them, I understand how the feeds differ from a conventional radial circuit, my issue is the initial testing. The feeds from 2 or 3 MCB's at the CU, go out via a module for the lighting system, to each of the legs being controlled.
Is it as simple as choosing the circuit within the specific MCB and measuring this for each and every leg? Pardon my ignorance please.
It very much depends on the particular lighting system. We've installed DALI systems where all the light fittings are supplied directly on a radial and they're all independently addressable on the comms side from the central control. I'm not sure how your system is configured but it sounds different.
OK......I'm going to make a guess here as there's several possible options. You've got a feed from the source > [control box/dimmer being installed by others] > lights on cables 1st fixed by you.
You do the normal collection of tests on anything that will have 230 applied to it, and ignore everything else.
Reply to Intelligent Lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
