Discuss Investigation on massive electricity bills in the UK Electrical Forum area at ElectriciansForums.net
I will be doing as advised earlier and fitting an energy monitor. Might do a week on the main DB and then a week on each sub mains DB. Not even sure if the other 3 subs come from the main DB as the cottage is close to the main house so may be fed from there. Will know more after my initial investigations.
Thinking may get away with a clamp meter as I've just seen the price of these machines. Just check current flows to each DB and see which one has got an unusually high current flow.
That will only tell you the instantaneous current flow, it won't tell you anything about the average demand.
I would say the first thing to do is contact their electricity supplier (the meter operator, not the DNO)
I believe they are required to investigate if there is a query about the bill.
As mentioned above if the bulls are estimate s this may be part of the cause. Have a look at previous bills to see if there is a gradual increase over the years or if this is a sudden jump up.
The expense of a data logger at this stage seems a little excessive, a basic clap meter will allow you to identify the circuit (s) with high loadings. If you can't identify an issue with this method then a data logger might be considered a robust method of demonstrating a meter malfunction to the DNO.
However, Do DNOs offer meter calibration testing - only charging the customer if no fault is detected.
Let us know how you get on.
I bought myself the Fluke 1730 Energy logger and it's already paid for itself at nearly 2k it wasn't a knee jerk purchase but I've had it hired out nearly every week since I bought it so it is now making money every week.
They are well worth the money, simply input the unit price for electricity and it will work out exactly what your installation is costing.
The logging period can be set from 10 minutes to 3 months and at the end you can print off the results or email them direct to your customer, equally you can drag snapshots off of it with a memory stick while it is logging.
We also use it to carry out load tests on machinery, some of our customers like to know what some of their large machines are costing to run for help with working out production costs.
Problem with such vague posts such as these as we are all guessing.
OP - you need to ask the customer to get out ALL their old bills, and
1. look at the amounts due
2. they need to check if they are estimated or proper readings
3. also log the consumption per quarter
- only then can they actually compare apples with apples.
with that amount of current flowing it shouldn't be hard to find.
Indeed not. If half the bill is wastage via leakage to earth, the L-E insulation resistance would be 8.2 ohms, so about a ten-millionth of what you might expect on a domestic system. You would want to search for it with a continuity tester, not an insulation tester, as that would just read a string of zeroes - 0.000008 Megohms if it had that many digits. Somehow I doubt this as the cause - the fault would be dissipating the heat of over three 2-bar fires, which I can't imagine XLPE SWA withstanding for over six months. The ground would probably be steaming! Although anything is possible until you get some data.
may be the electricity company they get
the supply from need to be involved and ask them.
Think this is the most sensible suggestion to check first. Why pay hundreds of pounds getting an electrician to check if there is something wrong with the electrical installation, if they've got some dodgy meters or readings.
Get the fuel supplier to verify their meters.
Reply to Investigation on massive electricity bills in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
Just under 2 years ago my central HVAC died. I wanted to go with a heat pump because the only appliance in the whole house that used natural gas...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
