Discuss IR test on DOL to motor AM2 in the The Welcome Forum area at ElectriciansForums.net
Does anybody know if you only to an IR test on the cables that you have pulled in from the DOL to the motor on the AM2?
So, you would just do L1-E,L2-e, L3-e,
Then L1-L2, L1-L3, L2-L3?
Obviously from the DOL to motor you will only pull in brown, black, grey then and earth with no neutral.
Reply to IR test on DOL to motor AM2 in the The Welcome Forum area at ElectriciansForums.net
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Hi all, hoping for some advice, I’ve recent resit my AM2s after failing on first attempt… I’ve passed all my resit apart from section C just on...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Fluke MultiFunction Tester 1662 TNS Earthing system. Switchboard - 415v - 3 Phase + Neutral + Earth. MCB 1000A 3 individual Earths (185mm)...
