Scrapyardthing
Hi
I have bought a new bathroom fan to replace a faulty one. I don't have much cable available (emerging from wall) and it won't stretch to the connectors within the fan without extending it. However, if I rotate the fan fitting through 180 degrees (ignoring the text and arrow suggesting where the "top" is), the cable will reach comfortably. By doing so the timer delay adjustment is at the bottom rather than the top which, I would argue, is also mildly more convenient. Does it matter if I choose to install it "upside down" like this?
The fan is wall mounted near the ceiling.
Thank you in advance.
