I've run the numbers and I came up with a value. I need to know if its even close?
And?, , ,Principles to run the machine
[1] an expandable enclosed container (X) of air submerged in water has a lifting force (Y) equal to the volume of the water displaced minus the weight of the container;
[2] connection multiple containers one on top of the other creates a combined lifting force of (Y)+ (Y)+ (Y)+ (Y)+ (Y)+ (Y)+ (Y)+ (Y)+ (Y)+ (Y)= (X) = the torque force
Which is a greater lifting force than (Y);
[3] the energy needed to fill one container is equal to the energy needed to sustain the combined lifting force of the 10 (ten) containersView attachment 59703
This has got to be a wind up. Y+y+y×y etc
or why not electrolize the sea water producing hho gas capture it in your container and retrieve it at the surface for further energy production. What is the sustainability of that process? Any net gain there? It would probably be more efficient than pumping air down.I understand what you are saying. The question is how much energy does it take to pump the air to a given depth for which the combined torque exceeds the amount of energy required to pump the air down there. kinda like a water wheel generator but in reverse. That is a damn good question but I would think it may consume more energy than it produces. Why not just run a straight pipe into the depth of the ocean and let the pressure from below force water out the top and capture that energy?
Not had that since I picked up my "FREE Battery at Tandies ..along time ago"to the free energy gremlins.
Blast from the past.Not had that since I picked up my "FREE Battery at Tandies ..along time ago"
... Come back Maplins..
Would a fish fart be liquid? Having what force? Then u gotta feed the lil bastards.......... eh forget itLook, we all know that the underwater conveyor would produce power.
problem is unless you inflate the air pockets with fish farts there is not a chance in hell that it will produce a net output of power.
unless *** of course *** we could add in the amazing power of magnets to the equation and it would obviously work. damn and blast, why didn't I think of that first?
