well if 1.5 is 17 amps
17/1.5 = 11.33 something
11.33 x 2.5= 28 something
11.33 + 28 = 39.33 something
This is better than the telly , if the MAN U game was tonight I would turn the telly off , Just wondered do you know Jeremy Beadle
11.33 + 28 = 39.33 something Since when did we have 3.5mm2 cable?
Its no where near that simple, and unlike resistance/meter its not a calculation or formula.
If it was you wouldnt need the 30 or 40 pages in the regs for cable ratings.
If you are going to insist on getting involved in things you do not understand then at least buy a regs book and familiarise yourself with pages 332-375 which will tell you all about cable ratings.
And then when you are finished read 318-331 which you will then learn about installation methods so you can reference the ratings carefully
the cable is not directly going into the MCB thats probably a silly answer.
no it would not as it would obviously get to hot deteriorate and catch fire.
thinking about it now a 2.5 mm cable can take 28 amps which would do the same however as it is a ring the 32A is split so there is only 16A on each leg therefore the 2.5mm cable which can only carry 28 amps or so is fine. in theory then you could do a ring in 1.5 although as it can only carry 17 amps and the breaker gives 16 amps per leg this is pushing it a bit.
see its in there
- - - Updated - - -
ignore that then
see its in there
- - - Updated - - -
ignore that then
You have issues.
A breaker does not supply 16a per leg, it has a capacity of 32a and a fusing factor of 1.2 if i remember correctly, that gives a tripping current of about 38a so it is possible to draw 19a per leg. so you could be subjecting your poxy 1.5mm to 38a
Not quite but beginning to get there.....
2.5's on a ring won't necessarily both take 16a as this would depend on their lengths and resistances. However this is a lesson for another day and we digress.
If the 1.5 will take only 17a and it is connected to a SOCKET ON A RING WHICH HAS A 32a MCB........(waits for it to sink in), what would you new to install to connect the 1.5 to, to make it safe?
Hold on, are we talking about an extractor fan or cooker hood?
Extractor fans can be installed on 1.5mm cable as long as it is protected by a fused spur (or for the first time me hearing FCU?) Cooker hoods would have to be on 2.5mm cable.
Am i right?
Apologies, but all these posts are just throwing me off balance here lol!
Edit: I appreciated Design currents etc.. would have to be calculated first in an ideal world.
just to answer quickly before i go back to working out markys post its a extractor fan rich
can you get a socket with a switched fused spur to fit a double box then obviously I dont know before anyone one goes omg I dont wanna walk in to the wholesalers and make an even bigger dick of myself nor do I want to ask my guvnor if he can get me one if they dont exist
Hey hey hey.!!!!! Well done.
Run 2.5 from double socket to spur.
Run 1.5 from spur to fan
I can sleep now!
But I gotta say you wouldn't believe the reaction my mrs has given me tonight. I have been falling off my sofa with tears running down my face. I have laughed so much in months.
Cheers Lads.. Brilliant.
the 2.5 is already run from the spur next door to the double socket it is then run back to the board. are you saying morve the cable from the double socket to the switched fused spur in the pic above.
ps i do appreciate you trying to help us here
- - - Updated - - -
well im glad youve had a good night mines been tough
i havent even had dinner yet or a shower and ive got to leave at 6 to be on site for 8. now ive got to go look at this thermostat upstairs
