Search the forum,
Discuss Is this within regs? in the UK Electrical Forum area at ElectriciansForums.net
im pretty sure you have and ive seen some very experienced sparks with gold jib who carried out work which was nothing short of a shocker.
i think it all depends if you take pride of the work you do.
yeah, I bet that all the other photo shockers on this thread were done by so called 'qualified' sparks who served apprenticeships, and not Electrical Trainee.
Correct me if I'm misstaken but that gland assembly looks suspiciously like Plastic??
This is a old thread guys.
And what's wrong with "old"???
You can't go around discriminating against "old" It's against the law!!
You seem to be suggesting that "old" things should be ignored and not spoken to.
I'm "old" and I don't like being discriminated against. We "old" things have feeling too you know!
I'll have the police on to you !!
Now behave your self and don't do it again!! :bobby:
You can't go around discriminating against "old" It's against the law!! being old should be against the law. euthanasia id king.
You seem to be suggesting that "old" things should be ignored and not spoken to. or put in a home.
I'm "old" and I don't like being discriminated against. We "old" things have feeling too you know! so do hedgehogs.
I'll have the police on to you !! if you can find one on a friday afternoon
Now behave your self and d.on't do it again!! :bobby:
obviously had to type something here or " message is too short".
yep. i'm well preserved. how's your man flu?
Just now the Tinnitus is deafening and the Meniere's disease is making me feel very queasy and unbalanced .. but being unbalanced is not a new thing to me.
I've gone a bi dyslexic too - I'm having to spell check everything which I normally don't need to, and the meds are making food taste terrible, so I suppose the upside is I'll lose a bit of weight.
You've been around the pouffs too long Geordie........... as for the food......... it's always been terrible. :rofl:
you'll have to stop putting rat poison in his food then. or are you just a terrible cook? :21:
Reply to Is this within regs? in the UK Electrical Forum area at ElectriciansForums.net
I'm working on a system that has been installed incorrectly. It's a 3ph Hager board with 8 swa cables glanded into the bottom entry panel. The...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi, With respect to the cooker switch only. If I moved it 400mm to the left by extending the T&E from its original position using crimps, then...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
resitting Saturday my am2 4 sections a3/b/d/e swa and sy failed on protective conductors on both swa i under stand thats the earths i...
