Discuss Is this within regs? in the UK Electrical Forum area at ElectriciansForums.net
im pretty sure you have and ive seen some very experienced sparks with gold jib who carried out work which was nothing short of a shocker.
i think it all depends if you take pride of the work you do.
yeah, I bet that all the other photo shockers on this thread were done by so called 'qualified' sparks who served apprenticeships, and not Electrical Trainee.
Correct me if I'm misstaken but that gland assembly looks suspiciously like Plastic??
Reply to Is this within regs? in the UK Electrical Forum area at ElectriciansForums.net
I'm working on a system that has been installed incorrectly. It's a 3ph Hager board with 8 swa cables glanded into the bottom entry panel. The...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi, With respect to the cooker switch only. If I moved it 400mm to the left by extending the T&E from its original position using crimps, then...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
resitting Saturday my am2 4 sections a3/b/d/e swa and sy failed on protective conductors on both swa i under stand thats the earths i...
