K
Knobhead
Including the winter?
The Velux ventilator would be open even in winter. It was my dark room, so I had filtered air drawn in from outside to pressurise the room.
If it is this size could you not take the feed off the loft sockets! or extend into the floor belows ring. Haven't seen may stand alone circuits for a single room on underfloor heating.
i havnt used any underfloor heating before, whats the average size of these for a standard 3x4 room? between 2kw & 3.5kw? if so i could use 2.5mm, make my job a bit easier and cheaper.
