Surely it is down to LABC to determine what cert is needed to comply with being "signed off"
As for doing it years later on other peoples work, then you are opening yourself upto a minefield.
ok years maybe a bit far fetched but being a good spark i wouldnt knock it back , testings testing
Erm negligance, who certified it? Glasogospark did. So why did the house burn down due to poor connections/ why weren't cables run in safe zone, etc
But as I say its your call.
if you are going to certify work that has been done by other sparks/builders/kitchen butchers etc. then the only cert. you can do is a EICR. say, for example you were a MOT garage. would you issue a MOT for a car if the owner said someone else had fixed it|? no. you'd do your own MOT.
Cricky tel you can understand the OP as well then :sifone:
I still maintain that an EICR is not a cert.......it's a report! We aren't certifying anything when we do one, we are merely reporting on what is already there.
yes but unlike yourself i wouldnt carry out an inspection and overlook such faults/problems as i am competent , obviously you dont deem yourself competent as you cant even fully inspect works that require a minor works cert never mind a full EICR
shut up you **** , question is ment on the basis i wouldnt be present when work is being completed and asked months or years down the line to check it and sign off , i know the difference between certificates
Insults because I couldn't understand your illegible ramblings ? Not my fault you are challenged in the educational ways pal.
And as for your question (now better explained) as to which certs you should use when signing off someones else's work, the answer is .... none, because you shouldn't be doing it unless you are a cowboy or a downright idiot.
dont agree
