J
Jamie
Got a call out today, No hot water, I get one of these call outs every couple of days, sometimes several in one day...
Turn up, Ask where the consumer unit is, water heater switch & tank is, go to the tank, take a look inside the cupboard and see a right state, electrical burning smell too...not a good sign to start off with haha, so back to the consumer unit and switch off so I can take the cover off and investigate...
http://i.Upload the image directly to the thread.com/kawcJiEl.jpg
No flex grip resulting in the Neutral being pulled out of it's terminal (I don't know why it wasn't doubled over, so the terminal screw/plate gets a even hold each side like you would a bonding clamp)...
http://i.Upload the image directly to the thread.com/6AnWheyl.jpg
http://i.Upload the image directly to the thread.com/7oQDqA9l.jpg
http://i.Upload the image directly to the thread.com/kbnzp7Nl.jpg
http://i.Upload the image directly to the thread.com/Ct4lNkgl.jpg
Re bared the cable, terminated it and made sure it was all working ok, got a new flex grip out the van, couple of screws, got to nip back tomorrow with a new cover as we don't stock them! So put the old one back on for time being!
I've never seen a immersion heater thermostat housing that bad....to the point where the actual round cover melts..
Did a RCD test and all came back OK....So I suppose the neutral just didn't touch the earth/metal casing, as it never tripped of? I was wondering why the RCD was still holding for a start before taking the cover off, as soon as I opened the cupboard door I could hear it buzzing away :ears:
Just thought I would share that with you guys anyway, Anyone ever seen a worse thermostat housing?
