Discuss Joining two 16mm twin and earth's together? in the UK Electrical Forum area at ElectriciansForums.net
DIN rail terminals or copper tube butt crimps in an adaptable box with glands.
In a cupboard most likely.The 16mm cables feed 3 flats which went into a single phase board.3 phase has now been installed approx 10 feet away.I need to extend the 16mm's to the new isolators.
Think I would do something like Lucien suggested. I’d source an electrical enclosure with din rail, and din rail connectors etc. Some Wiska or Sprint glands for flat cables.
Resin filled joint kit - it’s permanent and doesn’t need to be in a cupboard!
Unless you need accessible terminals for some reason?
Reply to Joining two 16mm twin and earth's together? in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi I have a domestic installation to rewire and the main incoming fuse is 80 amp so i am using 16mm double insulated tails, is the main earth size...
Hi, I have been tasked with a kitchen rewire. The current DB is fed by a 16mm armoured. There is a split load old contactum DB which I don’t...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hello Guys Looking for some advice with regards to a extension job. Customer has ordered a Rangemaster Induction Hob and Oven. I've looked at...
