Another case of not getting all the info in the OP, basically mine and your signature says it all Murdoch. If that fact was mentioned earlier the help may have been a little more forthcoming, sigh, never mind better late than never.
Agreed. All posters who give more "background" information always get a better, more helpful response! A lesson I learned VERY early on in my membership of the forum!!:33:
So by the "logic" displayed in the opening post a 3 amp fuse should be significantly smaller than a 13 amp one.
Why do you think you have to increase the tail size?
If the existing fuse is coping with the existing load adequately why on earth would you increase the CSA of the tails?
Following the "logic" again perhaps we should be thinking about what may happen load wise in a property 10, 15, 20 years down the line.
Of course....it's ten sizes smaller....
No no no, the first fuse was 1 amp so that is the reference value. The fuses will go up by that value each time so size one will be 1 amp, size two will be 2 amp, size three will be 3 amp, size four will be 4 amp, size five will be 5 amp, size six will be 6 amp, size seven will be 7 amp, size eight will be 8 amp, size nine will be 9 amp and size ten will 9.8 amp because that's the square root of 96.04 or at least that's what I was told :thinking:
weasel, with an e, seeing as you seem so fond of using eeeee s.
