Discuss Kitchen lights in the UK Electrical Forum area at ElectriciansForums.net
I've a feeling that you'll need to keep a laminate kitchen spotless if you're going to fit kickboard lighting but I would go with the LED strip. I've mentioned this in a quote for a customer - I think I put him of! Oops
i fitted 16 decking LEDs. 1/2" diameter. a few quid off ebay.
Reply to Kitchen lights in the UK Electrical Forum area at ElectriciansForums.net
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
Good morning, I'm in the process of a partial refurbishment which will involve the present kitchen being changed into a bedroom instead and the...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Now there's a requirement for a Fire detection in all bedrooms as well as hallways Lounge and Kitchens can the detectors be wired from the...
Kitchen led lights have all of a sudden dimmed by about 30% no dimmer in the system. There are 2 switches for this set of lights. Regardless of...
