Hi Dave,
Thanks for the reply, that is the original wiring so probably been put in before there were regs! Don't know how they're going to be routed then?? I'll have to get an electrician in, cos I can't see any safe zone way to do it!
How on earth did you manage to remove the plaster from the original wiring without disturbing the couple of clips that are holding it back to the wall?
That looks a lot like modern cable too,
looking at that photo showing the door, if youmove the light switch to the left, in line vertically with those cables, then you have a safe zone for them. ( or you could fit a twin socket lower down if you like).also, if there is a switch or socket on the other side of the wall, in line, then that will be an alternative safe zone, as the safe zone extends to the reverse side of a single brick wall.
Only if the wall is 100mm or less thick, most plastered masonry walls are >100mm thick.
Brilliant telectrix, I'll move the light switch as the switch cable is not vertically inline at present anyway, plus I need to change it to loop-in switch too. Sounds like the easiest option. There is a double socket on other side of wall but as radiohead points out it's a thick wall (once exterior wall before my time). Really appreciate you guys taking time to reply. Thanks.
[automerge]1590855795[/automerge]
Sorry, missed replying to this one, the plaster fairly easily came off and I was very careful. Depends which picture you are referring to though! The main two way light is new cable that has not been attached properly yet as I was waiting for answer about using conduit. Since I had an answer to that recently I can get that attached properly now. The cable with the door is old cable (don't know how old though as no electrical certificates).
Hi Dave,
[automerge]1590789563[/automerge]
Already know safe zones as Googled many times, those are the original cables that I need to replace (except cooker wiring), need advice on how to run new power in cable. No safe zone as door is in corner. Thanks for reply anyway.
Ono solution is to add an additional socket under the cables not in a zone.
Hi thanks Super.sparks, yeah that was suggested by telectrix too, so it's the best option.
Thanks everyone for replying so far. Any answers to other queries would be useful too.
