Discuss Klein tools???? in the Electrical Tools and Products area at ElectriciansForums.net
C
Canadian
Over the last few years I have had to replace my Klein screw drivers a number of times, due to the tips rounding off or snapping. I talked to my crew and they have found the same issue with the newer Klein screw drivers but the older (10 years plus) are still like new.
Have you guys found the same thing?
If you have found a better longer lasting screw driver let me know because my crew and I are ready for a change.
I have been reading the same things on US forums.
Klein do not have much of a presence here in the UK, with only a few suppliers.
A lot of people here recommend Irazola screw drivers, but I personally dont like them too much.
For quality I would go with a German brand.
Take a look at Wera, Knipex, Wiha etc.
mine are ok. i got the set in the red tin. i would email them and complain you never know they might replace them for you
i have a huge range of Bahco tools, including vde screwdrivers, good stuff and currently owned by or own
Snap on (cant remember which), would recommend, failing that go german, specifically elora
Reply to Klein tools???? in the Electrical Tools and Products area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
I have an older Crouse Hinds board with a 200A service. Due to recent rehab on the house, I found I have the need to install a sub panel. I...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
