Discuss L-E 240v L-N 12v N-E 120v in the UK Electrical Forum area at ElectriciansForums.net
Hi guys read plenty of things on these forums and now have a problem to post...
Fitted a fan heater to a spur in a bathroom today. The spur is on 16A breaker and appears to be a radial. Fitted and switched on at DB and spur but no luck.
When i tested the spur I had 240v between line and earth, 12v between line and neutral and then 120v between neutral and earth.
At this point I isolated the circuit thought I’ll save that one for tommorow so just wondering has anyone experienced this before as I’ve never come accross this before
What you meant to say was I tested it couldn't make head nor tail of the results, so I'll ask on here and go back tomorrow with the answer.
As above and above the other one Floater and nobody likes a floater!!!!!
Ok your one of them.
Been sparking 10 years and never asked anything on a forum got a strange one today and thought I’d share it.
Thanks for any other sensible responses
Been sparking for 1o years? matey I was Sparking as you put before you was born
Been at it a long time but had to look up how to wire a 2way cct when both supply and lamp feed are in same switch.......never wired them like that and never come across it as dont do much domestic.........so to be helpful if you are measuring L-N on output side of FSU could be poorly FSU neutral side, if you measured it on the input side then would trace cct back to breaker and find the neutral and test
Reply to L-E 240v L-N 12v N-E 120v in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I was called out earlier today to a house where a plumber was fitting a new mains electrics shower. He wanted to know if the existing...
Earth to Neutral 2 ohm with Multimeter on alighting cct. The cable disconnected from the switchboard. I am new here and appreciate everyone...
Good afternoon all, today I experienced a near death electric shock. This happened on a single phase domestic property! I was carrying out a few...
Looking for some guidance here. I'm currently shadowing a guy and we're testing a new extension on a school. 3 phase TNCS supply from the original...
