S
sparks1234
Evening guys
We are carrying out a small install and we need a bit of RCD protection on some circuits for which I was going to install some RCBO's
The dis board is a Lewden which was preinstalled by others, never worked on that make since the old screw cap sockets
Now, the RCBO's turned up, marked as RCBO but they look like any other companies RCD's, i.e. they have the phase and neutral feeds one side and the load on the other side rather than a flylead for the neutral on the neutral side, anyone come across these before? and, does anyone know if they do a "proper"RCBO
Just to add, it would have been quite easy to install the RCBO straight across 2 phases on a 3-phase board
Hi
Sounds like you have got a double pole rcbo, we use the single pole often and are quite good for the money.
Regards
Gary
Merlin DBs did and maybe still do a conversion kit to fit a dp rcbo.
It was/is a kit which changes a phase stab to neutral.
Took a lot of fiddling to fit them.
Boydy
