P
Peter Woodford
Is it right that if I am changing a normal bayonet fitting that say holds a 60w lamp and a new fitting of a different design but still holds a 60w lamp do I still have to
issue a minor works cert
Mmmm...one of those!.
If, strictly speaking it`s not a like for like replacement, then you do
but if its basically the same fitting but a slightly different design then you could argue it`s a straight swap.
Only really you could assess it Peter
Is making out a Minor cert gonna involve loads of testing for you?
Special location?
I dont think it even warrants a cert at all, as no modifications are being made to the fixed wiring.
