Discuss light for use in well in the UK Electrical Forum area at ElectriciansForums.net
A customer has built a consevatory that has a 40 foot well in the middle, he has then built a wall around the top and had a slate top with a glass top fitted, making it into a circuler table.
We put a cable to supply a light at 1st fix stage.
We have now been asked if we could get a light fitting that could be lowered into the water and uplight the well from the bottem.
Has anyone got any idea of who might make such a light fitting.
Ta
We did a job not so long back which was very similar however the well wasn't as deep. we found that the lights actually looked better towards the top of the well shining down on to the brick work as it gave a much better effect. We fitted some blue collingwood LED lights which were very effective although pricey. Consideration should be taken in to where any drivers, connections and cabling will be hidden and accessed in future
edit: grammar
Reply to light for use in well in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Whilst having some building work done we discovered a stone lined well under our new kitchen floor , It is 25' deep and hand dug (through shillet)...
I'm not trade. Q about light fittings and water. Our village hall has a bar, with a sink for glass washing. We want to put a light above the...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
