Hi,
I'm fitting a new lighting circuit into my garage consumer unit that will feed 2x outside wall lights.
I plan on using a two way circuit to have an external switch and one located inside the house.
The attached picture is how i plan on wiring but i have one question about the Neutral feed from the CU.
Shall i take the Neutral directly from the RCBO or from the Neutral Bar and its corresponding circuit?
Many Thanks,
Many Thanks,
Its often met with warnings about the Part P procedure
