I have this calculation in my notes somewhere .. Candelas and all that mAlarki, never actually put it to the test, but I shall sometime
4x14 watt t5 600x600 Recessed lights with prismatic controllers and have 2 tiles between lights width ways and 3 tiles length ways, it will give 450 lux at desk height no problem if all on, make sure you add plenty of switches in so the customer can isolate areas which are not in use. However that said, it is so easy to just get your wholesaler to work it out via their lighting company and it will be right first time.
i will post a pick tomorrow if i get a change to pop in of a place we done roughly the same dimensions as mentioned plus suspended ceiling , we used the fitting i mentioned earlier 3 rows of 4 , was for a bike workshop , gave us 850 lux when lamps where new , the fittings mdj mentioned would look better and do the job just as good but would cost a lot more
