I
ianphilip007
hi guys
wondered if anybody could clarify something, when you need to change a faulty extractor fan like for like does the fan circuit now have to be fused at 3 amps ?? AS PER MANUFACTURERS INSTRUCTIONS for the new fan or can the fAULTY FAN BE JUST REPLACED to existing circuit as is.
i guess its weather the you say that the existing fan circuit SHOULD have been fused at 3 Amps and is non compliant. or that the manufacturer has changed their instructions making the circuit non compliant.
im confused as a simple fan change now involves rewiring the entire circuit to provide the 3a protectiion, if you do indeed have to follow the instructions of the new fan.
