K
Kieron Nolan
Hi
I was using a stud finder before drilling into a wall and was surprised to discover a large area of the wall showed up as live. I've read on other posts and am worried that during the build a cable was pierced by a nail and subsequent damp present before the windows went in means the whole wall is live. Should I be worried, or are stud finders generally not that accurate? Attached is a picture taken before the plasterboard was installed - you can see a cable running along the wall just above the horizontal spar about halfway up (on the left hand side of the picture - the X pretty much marks the spot I'm working on).
Kieron
Can't you identify the circuit, disconnect it and IR test it to start with. You can also test if each of the nails or screws holding the plaster boards are live if they're still visible.
Not in timber frame, no. Well, it's incredibly unlikely given that wood is an insulator. Suggest it's time to test the cable to make sure, then buy a new stud finder. They're all pretty rubbish in my experience.
Heard of this at a row if terrace houses numerous walls live along the whole row turned out to be a manweb cable that had been pinched so even when all the houses isolated wall still live,
Took months to figure out with loads of people having a look into it.
It was a mate of mine who told me that his wife had a belt when in the shower and called land lord who said so have other people crazy what goes on out there
I'm more intrigued by the out of zone cabling crossing that door header, tbh. Esp when it [looks like it] could have gone up and out the way completely.
I can easily isolate the circuit, I'll try that tomorrow. The house is finished now though, so no screw heads are visible to test.
Ah, what I haven't told you is that this is my house built in Australia. They do things a bit different here. No single copper wire here, it's all stranded. I've queried things on the way and I've been told that Australian regs say blah blah blah hence me wanting to get advice from the UK (which is where I'm from). The damp was a huge issue after moving in as they didn't vent the bathroom and kitchen fans externally, only to the loft space. We had mold 2 weeks after moving in and needed dehumidifiers to dry it out. They've since done what I suggested in the first place. So, with all that damp in the roof, it's possible it could have made it's way to the walls.
i tried turning your picture upside down, but still can't make out where you say the problem is. if you like, i'll fly over and sort it out for you £25,000. ( 10% off for cash ). :crazy::13:
If there'sstill damp in the walls it could cause the stud finder to give unusual readings but It's worth mega testing the circuit at 1000 volts or even higher as long as everything including lamps are removed first.
Or the ones running horizontally around the room!
like keiron said, it's in Oz. their prescribed zones might be different to ours in the UK. for example, our regs. don't allow for the possibility of kangaroos jumping on cables.
so...she was wearing belts when in the shower...
hmm...sounds kinky...
of course its worth IR testing it...
otherwise its just effectively taking the readings of a glorified volt pen as gospel...isn`t it...
I've decided I quite like this thread!
:rockon:
