Haha, we have a guy who works for us and he locks the windows in the van, always gets our lads gagging. He's a right dirty bawsterd
how do you all replace a consumer unit without pulling the main fuse or waiting 6 months for the dno to turn up?
To be honest, I've never had to wait more than a couple of weeks. Gives me time to plan work in more easily, as I can't do the CU change by Law until the supplier has installed an isolator. ;)
i found a big yellow 240v do not touch sticker, somewhere in the skip, printed "Electrician at work, do not touch" on a piece of laminated paper, stuck both onto some plywood, hang them on the consumer unit/distribution board/utility room in question when working somewhere away. did the job for elecsa assesment.
Posters and signs are all well and good..but...i saw a bus the other day with "kelloggs" wrote on the side,but it was'nt full of cornflakes...
if its THAT big warehouse or industrial facility/nuclear power station i would include my mobile number to be put on the sign.
if some monkey wishes to kill me they will take cover off the board and short the mcb with some wire.
Hi bick
Did look at hem but seem a bit cheap in quality
I have one and use it ( or used to use it ) and it's fine for your normal domestic stuff and maybe commercial as well. It will do all the lad wants it to do for his assessment at least.
It's not as "cheap" & flimsy as it looks - it's a lump of solid extruded aluminium and I think there is more chance of snapping the toggle off the breaker. The weakest point is probably the hasp of the little padlock.
At the end of the day EVERY lock can be defeated by someone who is sufficiently determined to do so.
How far do we want to go with this just to stop someone accidently livening-up a circuit??
I'll bet there were one or two crackers on it though.
We use a panduit kit at work it has a couple of mcb locks as well as lockout devices for valves. We also had to get a couple of plug locks as someone decided to plug in a transformer when a sparks was working on it (transformer on floor below). We use a Lockbox system so if you're working on a system you put your lock on the box and the last lock to come off is the supervisors. Saw locks with an individuals name and picture on them on one site.Not a bad idea as we all have probably come across locks with the tag missing and not known what works ongoing
Hi thanks for all the useful input, getting the kewtech one my daughters just bought it for xmas. Than goodness wont be getting sock and undies again. hope its attached to bottle of baileys lol
cheers
Dave
he wont need to see lock off devices...
he will want to see that you can carry out a safe isolation procedure in a competant manner...
and as far as my post at #7 is concerned....why do you think that the only reason to invest in lock off devices is to impress some assessor someware?
Competent
Somewhere
I suggest you use your ban time to brush up on your spelling son.
my arse has been kicked more times than the matchball on cup final day...
never worked on me im afraid....
Slow learner evidently by the amount of times you have been corrected on basic spelling and punctuation son. Wise up.
Competent
Somewhere
