I made a typo in OP.
I have 2 cables. 1 switch 1 supply.
Neutral wire in switch is 'live'.
I know how the wiring works.
My only question is at which part of the upstairs downlight circuit can I cut and connect all the wires up in a wago? Does it really matter at which loop in downlight cable I cut into?
The forum rules don't allow step by step guides to be provided.
Your approach is wrong and will not result in what you want (which appears to be a loft light you can turn on and off independently of any other).
The best advice we can give you is to engage the services of a local electrician (preferably one that comes recommended by family/friends/colleagues). For any quality spark, this is a fairly simple job and should take no more than a couple of hours.
less than 1 hour if the pub is open.
