_q12x_
Hello from Romania.
I have all the counting ccts, for every number. This is counting to 16 and its the last one this 7493 can count.
I encounter a new and very weird problem. All the [Q] (QA,QB,QC,QD) outputs of the 7493 are not so good at outputting. At least to my components I tested so far.
I simulated more possibilities and all failed. I thought maybe the simulator is not that good. But when I tried the BJT in reality, it still didnt work. I really want to believe it will work with opamps in reality, but if it will not work, it means the simulator is right.
I didnt try with mosfets in the simulator yet, they were just prepared there. I didnt test them in cct.
THe problem is the (-) that 'comes out' after these buffering devices. When they are on (-) on their output.
I actually solved the problem using a tri-state buffer. They are the only component that are solving this issue.
Ive also get 10 pcs from aliespress. I start to value them now, when I actually need them. But they will arrive after 2 or so months from now.
- I want to find a solution (IF POSSIBLE) without them, or at least until they arrive.
This cct I already make and it is working fine (in the simulator) is to output a decimal number for all the 16 binary counts.
Pretty much when is 0100 it will lit the 4th LED. When is 1000 the 8th LED and so on, from 1 to 16 (including 0).
You can see in the screenshot already.
I work on this cct and numerous problems for .... about 10 or more days. Very hard to do it alone !!! But I did it. so far.
I even have an easier output method than this very complicated cct I already built.
- Simply to display in binary. Like these 4 LogicProbe from Proteus simulator that I am always take for granted.
So we can do these first !
To make a simple binary counter [LED display], I will still need some sort of buffer, like the ones I specified already.
I wait for your response. This is a very complicated cct and a big problem for me.
Thank you and hope I will get some interesting answers! (mister @marconi , my Logical friend?haha)
And also Happy New Year 2023 to everyone that are reading my posts !
