Discuss Long HDMI cable, Sky to TV in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Midwest
I'm just finishing a part rewire on a friends house that's been extended. He extended the kitchen into a new lean to style conservatory. In the conservatory, he's positioned new TV. He wanted to watch Sky on the new TV, but didn't want to buy another Sky box and pay for multi room. Not being an expert in these matters, I told him to get advice from others.
He did, and I was told to run a HDMI cable from original Sky box in living room to conservatory, as well as 2 x cat 5 cables, as back-up. The new HDMI cable would eventually run from a splitter by the Sky box. He had a shred load of satellite cable, so as a back I suggested and ran 2 x from new tv to Sky dish.
He purchased a 25m HDMI cable, for about ÂŁ30. I did suggest he spent a lot more than that, because I'm led to believe anything over 5m in length needs to be good quality?
Any how, when he connected new HDMI cable, the tv doesn't detect a signal. I've told him to get back to his adviser.
Will this length of cable ever work?
Thanks mykey for the link. I use that forum, but I thought I would try here first. I've done a little more digging and see that some long hdmi cables use an in-line extending booster, which I think the installed cable might have. However, when installing said cable there were no instructions and no suggestion on which cable end should go to what. So I need to check that.
Unlikely that length will work (I would say would never work but someone is bound to say I am wrong!:), best bet would be to use a cat5 to HDMI Balun which would work over that distance, probably be cheaper than what it cost him to buy the useless 25m HDMI cable.
Good news, for me anyway. HDMI cable installed correct way round, I new I would of done :). My mate had a bit of a play with Sky box & new TV, and got it to work. But the picture frequently breaks up.
He's has a splitter after the Sky box (1 to 2), but not a powered one, and I've read that non powered can be a bit of a drain over distance & number of cables connected.
I'll post on AV-forums (just in case anyone here is interested). I'll wait and see what his adviser got to say.
If you have a cat 5 cable from sky box to the new to then you could use a hdmi extender set. Basically HDMI goes in to the extender sends the signal down the cat 5 to the receiver and then a HDMI lead goes to the to from the receiver. You would need a socket at the tv end for said receiver but if not then you can get them with PoE. They can pass IR signals too. I've fitted hd anywhere and wyrestorm in the past and not had problems.
Thanks tomspark, the bods at AVforum recommend the same set up, although they suggest using Cat 6, someone recommended Cat 7.
in this instance over a 25m run cat 5 should be fine and do the trick. If It was a new build then I'd probably use a drum of cat 6 due to the higher bandwidth and to help future proof to an extent. As for cat 7, I'm not sure there is a standard for it yet.
Don't shoot the messenger, but the AV forums bods seem to erring on the Cat 6 route (not just in my post re this issue) over Cat5. They don't see the worth of Cat 7 at the mo though.
Reply to Long HDMI cable, Sky to TV in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi all, Looking for some advice on first fix for sky and freesat TV, I've quoted a WF100 shotgun and a single to both bedrooms and lounge...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
I have moved into a new build house and need to set up my TV, Computer, Internet etc. I need to have a TV aerial installed. I am confused by the...
I'm having a bit of a disaster at the minute and would like an honest opinion. I am having a gas stove fitted in the corner of my room and...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
