Hi, 3 sockets in my kitchen have stopped working. Yesterday I had the washing machine running, the breaker suddenly went and once switched back on 3 sockets no longer work. Any thoughts on how to fix? I looked behind one outlet and could not see any loose wires.
A pic of your fuseboard showing the type of breaker that tripped would be useful.
Jumping to the conclusion that the washing machine caused the trip, which may or may not be right, it would be wise to unplug it while trying to get the circuit working again.
This is a real long shot, but if it's a 13A one, you might try replacing the fuse in that fused spur. You would need to lever out the little white drawer highlighted below. Beware the fuse falling out and disappearing! Switch off first!
May not be that much of a long shot Avo, it may just be the picture, but it doesn't look to me that the neon light is on in that picture, but switch looks in the on position?
Joanna, did you check that breaker hadn't tripped again? reason I ask is a capacitor had gone on a washing machine I had and it kept tripping the breaker (it also happened another time with a capacitor in a dishwasher)
Hi, thanks for the response! You are right the light is off but the switch is down - do you think that unit has malfunctioned?
I've checked the breaker several times and tried switching it on and off as well but no luck. I managed to plug the washing machine into a working outlet and it seems to be running as usual.
That's useful, thank you.
So the "residual current" device tripped, implying there was an insulation (electrical leakage) problem, maybe water has got into some electrics, possibly the washing machine itself. If a major 'fuse blowing' event had occurred, I would have expected the Proteus circuit breaker to its left to have tripped.
The mystery is, if only the RCD tripped, why is power not present when you have turned everything back on.
Did you investigate the fuse I suggested?
I am a bit concerned someone has written "Kitchen Sockets" above that RCD. That RCD provides leakage current protection to the four circuit breakers to the left of it, so it's not just for the kitchen sockets, but also whatever is connected to the breakers on the left. Those are the 'fuses' to protect the circuits against overload.
Assuming for a moment nobody has wired that RCD directly to your kitchen sockets, and they are correctly wired to the B32 breaker (labelled sockets) to its left, could you please try the following: Un-plug the washing machine (not just turn it off, you need to pull its plug out of the wall socket), and then flick off both the RCD that tripped, and the one to it's left, and then firmly turn them back on, do your problem sockets come back to life?
If not, and you have already changed that 13A fuse I mentioned, I think you may need a competent electrician, though somebody here might be along with a better idea!
