K
kingeri
In my loft conversion, one of the bedrooms has a built-in wardrobe. I'm having problems with condensation (and hence black mould) in there, probably because it's enclosed and the heat from the room is not reaching it. I've done all I can to increase ventilation, with no improvement. I've seen these tubular 60-120w heaters and wondered if it might be worth trying one of those in there? Anybody have experience of this kind of thing?
The tubular heaters work well, I would have thought 60W would be excessive for a wardrobe so stick it on a timer. The other possible reason is a cold wall/ceiling without adequate insulation causing condensation. I would always go for fixing insulation/ventilation first but if you have tried these then a heater is next.
Hi
I had a nasty experience with one of these which may be relevant. A sleeping bag came in contact with the heater. It melted and filled the room with acrid smoke overnight. I'm sure it would be OK, but I would suggest also fitting a wire mesh guard over the tube. A room stat may be better than a timer.
Thanks guys. Insulation and ventilation are as good as they're gonna get. Will put heater on a timer and will defo fit a mesh guard! Probably gonna take a bit of experimenting. :)
They are effective the tubular heaters, they just need some control ie thermostat or timer...
Will be perfect for what you need...
