P
paul11
Can anyone tell me if there is any documented guidance on the use of PVC or LSF cables. As in when you should use PVC and when you should use LSF?
i know now the reason for using LSF. But would like to know when I should be using it.
also it is not mention In the specification of the specific job.
Example 1, fitting out of a store inside a Supermarket (existing is grey t&e)
example 2, re fitting of a bank
If LSF is not asked for in the spec, don't fit it. What with it being that much more expensive and a pain to strip.
Two places I've worked where it was on specs, were a school and a hospital. We come to the conclusion it is used where general public or children are in case of a fire.
Thanks Andy.
in all shopping centres and public places is it not a regulation that it has
- - - Updated - - -
I.E. shopping centres
Thanks Andy.
- - - Updated - - -
Not a regulation that I am aware of, unless part of building regs that I don't know about, but I highly doubt it.
I too have only seen it specced on school tenders before, but I have also done school jobs for the same LA that have not specced it.
Only use where specced, I hate the stuff in comparison of standard t+e, unfortunately recently I've had a lot of work with lsf, NHS walk-in centre being one and a bar/restaurant the other, I've found it depends on the manufacturer as to how easy lsf is to strip, had some recently looked like figure 8, a dream to strip for lsf.
i score with a stanley, then strip.saves whacking your cutters in your face or your hand on the wall.
I use bahco heavy duty cutter/stripper, cut down along the earth then use the top notch of the cutters to pull the earth through. They don't slip off under force like standard snips
Wow, do they actually ''Spec'' T&E for hospitals and Schools now?? How things change, and always in a downward trend!!
Shows the way things are going downhill. Last hospital or schools I worked on everything was in a galv trunking / conduit containment system wired in 6491B LSF singles.
Same as all the ones I have worked on.
Never seen t+e in a hospital around birmingham, black country or in the odd school in Kidderminster etc
I use LSF on all school work as the county council standard specification says it has to be used, otherwise as Andy mentioned in post 2.
Every job we tender for, gives a full cable schedule of cables to be used......never seen a schedule not using lsf
Same here. Just because LSF has been specced surely doesn't mean they meant T&E?
