Quick question, just upgraded my friends consumer unit, it is one of the 5 jobs to be checked by the NICEIC. To go towards me being certified by them. He needs his main earth upgraded as it is only 6mm, he has 16 mm flexible earth cable which he has acquired from a past job. Does it matter that it is flexible can I use this? I have google this and can not find nothing.
Thank you in advance
Jimmy
Thank you for quick reply. I can not see nothing to indicate it is tri rated, which I google and there's no BS number . It is rated 450/750v 16mm CCC A004540 60227IEC02 (RV) IEC 60 332-1 YOURONG OPTICOM.
That is a Chinese cable that may or may not meet current British standards, it does state it meets the fire resistance test.
I would not like to use it, but it is 16mm copper cable.
Ok thank you Mr Burns, I have put it in for now, gotta be better than 6 mm and will replace British standard cable before the NICEIC check. See it was a freebie job, was trying to prevent me mate occurring extra costs, as originally he wanted to wait till he was financially better off, Wouldn't of been a problem otherwise. :)
Thank you for quick replies
you`v to watch it n all with them fine stranded flexible 16mm G/Y....they can be a bitch to get into the PME link...
I wouldn't be worrying too much at all, the company you mention is a respectable one, and have used it's cables on the last project i was on in China. Not all Chinese companies and products are bad or inferior, as many that don't know any different would have you believe or infer!!
Yer, I mean how fussy are NICEIC? is the underlying question as they will be checking it. If it come down to my judgement I am happy that it is suitable.
i don't think you have any problem using it. as eng. said. not all chinese products are rubbish. where do you think ipads and nissan vans are made?
Well thank you everyone, I let you know 4th June when they check it. I prob have some 16mm British standard by then for back up and actually see what they say, but I am past worrying really.
- - - Updated - - -
well as long as it passes visual....and theres another thing as well....the G/Y is not a live cable unless under earth fault conditions...and even then only until the OPD/RCD clears it
